Thanks for verifying the link works
@Curious Hound .
I had started writing this in advance waiting for someone to verify the link worked.
So I will now explain what was going on with my truck.
The radiator hose you see leaking in the video I unhooked when I took the transmission out of my truck so I'd have better access to the exhaust manifold on the passenger side.
Evidently when I tightened up the hose clamp on that radiator hose the clamp broke somehow someway.
But that happening when my truck got warm as I was driving it around it got warm enough to put some pressure into the radiator system but not a lot to where it would shoot out of the hose like it did in the video.
It must have just been barely leaking onto the intake Manifold and onto the valve cover as well.
Then once the water fluid whatever you want to call it was on my valve cover it was rolling around the valve cover and dripping down hitting the manifold and boiling there and that's what the bubbles was about.
At least this is what I do believe.
I bought a new radiator hose clamp and since I've replaced it I've not had that problem again.
I've drove my truck five times today.
The transmission is for sure slipping I've checked the transmission fluid approximately 10 times today and it's right at the very top of the hash mark on the dipstick.
So I believe when the transmission fluid came out when the front seal messed up, and I added more fluid in it so I could drive it home I may have messed up the transmission.
I've got more inspections to do on the transmission because I think the lines ain't tied enough at the transmission either.
Because I could see a puddle, where some fluid leakage happened under the truck where it was parked at behind my brother's house right around the location of the transmission lines hooking up to the transmission but it also could be the transmission pan gasket leaking as well.
Once again I wrote a book.
I have a tendency to do that.
