Okay I've now finished helping my brother Larry so I can now post more on what I experience today.
I was told from the beginning that the truck I'm working on does not get any spark. And that the truck's owner already changed the coil.
It being a 3.0l it only has 1 coil and it also has a distributor.
Before I actually touched the I.C.M. I unplugged the spark plus wire from the distributor from the coil.
I then put the battery back in the truck.
I then h
Put the alligator clip from my test light onto the bolt sticking out through the nut on the battery terminal for the negative battery post.
I then touched the pick part of the test light to the positive cable terminal on the positive battery post
The test light lit up.
I then put the key in the ignition and turned it to the arm position.
I'm sure you guys don't want every last little detail so I'm going to skip and just give a brief recap.
I'm tested everything I could think of to see if it had power to pulled relays, I pulled fuses, I took the wire connector off the distributor.
As I already said I tested everything I could think of.
I found power where I didn't think I should find power.
The fuel pump relay has power at all four posts.
The E.E.C. has power at 3 of it's relay posts.
The coil has power to the 2 red/yellow wires.
The tan/yellow ( I think it's tan/yellow) that makes up the other side of the coil wire connector did not have power.
After about an hour of trying to figure out why there's no spark I finally unhook the I.C.M. and took it to get it tested.
It tested bad.
So I called the owner of the truck and told him what I knew at that time.
He told me to come to his store and get some money so I could buy a new I.C.M..
So I I bought a new I.C.M. for the truck and put it in place.
At that point I was in high hopes that it would fix the truck.
This first picture is the first I.C.M.
This next picture is the new I.C.M.
And yes I use the little packet of white grease looking stuff or whatever it was in the packet with the new I.C.M. I put it between between the new ICM and the little plate that it screws too that then the plate goes to the core support.support.
However it didn't fit the truck it still doesn't have any sport.
At this time any and all input is welcomed and greatly appreciated
