I'm sure I got a short.
Made funnier by that fact that sloth is literally how it works. LOL
Y'all were busy last night. I was tired. So I turned off the world and went to bed early.
Great progress has been made. But let's clean up a few minor things.
First, I would recommend using the resistance range shown in the book for your fuel level sender. My book also shows 22.5 ohms empty and 145 ohms full. Unless you completely empty the tank or completely fill the tank or pull the sender out of the tank to manipulate it with your hands, we don't know exactly what the current resistance value should be. It should also be noted that if the truck sat for a long time with fuel at a certain level, there could be dirt, varnished fuel or corrosion on the part of the sender that was exposed to air and moisture for a long time.
Next "slosh module" or "anti-slosh module"? Technically it should be anti-slosh because it's purpose is to counteract the action of the fuel sloshing around in the tank and making the sending unit float rise and fall violently. Ford called it a slosh module right there in the book. So, that term should be good enough for our discussions. It just uses some electronic wizardry to slow down the changes in voltage signal coming back from the sending unit so that the gauge in the instrument cluster doesn't try to mimic the crazy actions of the sending unit float. Trust me. You don't want to watch that dance. (Similarly, people will talk about "sway bars" in their suspension. They are actually anti-sway bars because they reduce or counteract the swaying motion of the vehicle. We are just lazy and dont want to say anti-sway bars.)
I like your comparison of the ohms symbol to a set of headphones. It is the greek letter omega and that is the official symbol for ohms, the unit of electrical resistance. Your meter has several resistance ranges. When using a multimeter, you always want to choose the range that most closely corresponds to the range of values you expect to measure. In this case, you are hoping to measure values between 0 ohms (short circuit, like a bare wire touching ground) and 145 ohms (full value of the sending unit).
DMM. Stands for Digital Mulimeter. That is the meter you bought. It is called a multimeter because it can measure multiple things like ohms, volts and small amounts of amps. A meter with a needle that sweeps across a scale from side to side is an analog meter or analog multimeter. But almost nobody calls it that or abbreviates it as AMM. So, we will usually just call it a meter or multimeter. If somebody says to use your voltmeter or ohmmeter, just use your multimeter set to the proper scale. The meter you bought should be adequate for almost anything you need to do on a Ranger.
People will often use slang terms, abbreviations and acronyms in discussions like we are having. I try to avoid this or define/explain the term when talking to a newbie who is just learning from the start. Don't be afraid to ask (as you have done) when someone uses a term you're not familiar with. Someone else may be reading the thread and they dont know either. So, it helps everyone.
Pot. No, we're not talking about drugs. This is an abbreviation or slang term for potentiometer. A potentiometer is a variable resistor, sometimes also called a rheostat. You have been using them all your life. The volume knob on a radio is a good example. You turn the knob and it changes the resistance that the circuit sees. The fuel level sending unit is a big, clumsy potentiometer. As fuel level changes, it raises or lowers a float on an arm that acts as the knob on the potentiometer and changes the resistance. The way the circuit is wired, this changes the voltage sent to the slosh module and gauge at the intrument cluster and makes the needle on the gauge move accordingly. That's the simple explanation. In that other video, the gentleman is just substituting a manual potentiometer in place of the fuel level sender so he can test the slosh module and gauge.
One other helpful hint at this time. When you disconnect a plug in a wiring harness, MOST OF THE TIME (no guarentees) the female side (has the holes that the pins slide into) will be the part that goes back to source voltage, like the battery, fuse, etc. And the male side with the pins will go to the device, like the fuel sender, windshield wiper motor, radio, etc. That is to help prevent a disconnected plug from touching ground and shorting out, which could blow a fuse, destroy a circuit board or even start a fire. It's just like in your house. The receptacle outlets in the wall are female. It's difficult to accidentally touch them and get shocked. The plug on your lamp cord has the male part. It is exposed and you can touch it. But when unplugged, it is dead and safe to touch.
Thanks " Curious" for the explanation of everything.
The thing I like the best about TRS forums is I always learn.
Each person has their own way of explaining things and I like that.
So it's cold as all get out outside and I got no garage.
I don't know when I'm going to work on my truck. Or going to be able to go to
" PickYourPart ".
They have a 93 Ranger there can anyone tell me if the, SLOSH MODULE out of it will work in my 94?
I took most of today to sleep in.
I laid down last night and it took me forever to fall asleep.
I've had problems falling asleep all of my life but last night it was compounded with pain.
I've done something to my right shoulder I don't know what but it's been hurting for about a week now. Last night it was really bad.
Everything I'm seeing says '89-'94 should all be the same.
Thank you Curious.
I looked on, Car-Part.com but I think that site doesn't like me half the time I get on it I can't even find the part I'm looking for comparison on.
FWIW, I knew Doug was a newbie months ago when he first started, but was kinda treating him like an old hand at this point.... I can type pretty well but still I get lazy and abbreviate.
I think you could pull an anti-slosh module from a whole lot more than just rangers too - it was kind of a bread and butter part that was in everything, you notice that video I linked they guy was working on a taurus. Mustang forums are rife with people having issues too. I looked but can not find the interchange, if you have part numbers we could look up the interchange a/o any junkyard you go to could probably find the interchange as well. I bet they are the same on just about 80-90% of 1994 model year vehicles and would work for you.
That said, I know they added more pins at some point so there are some changes, it's not a 100% universal part.
One thing the wiring diagram does (and it was in the video explaining the wiring diagram) is show the gender of the connectors. That is the best way to know. The rule of thumb is great and works most all the time, but not 100%.
For those skipped the vid here it is:
The little arrows at the connector denote gender of the connector:
Good post Brain.
I'm dyslexic and can be slow at learning things.
I learn faster and easier hands on.
I also learned faster and easier verbally rather than reading things.
However I do catch on it just takes me time.
I really do appreciate everyone's help.
Well folks I started my truck, my plan was to go to the golden arches.
I got close to about halfway there the heater was just warming the truck up everything was going along fine.
All of a sudden my truck started running really bad. With black smoke coming out of the tailpipe.
I thought I'd blowed it up somehow.
I turned off the main road and babyed my truck back to my house.
I pulled the hood lever (truck still running like crap) got out opened the hood the rest of the way. Looked around didn't see no vacuum lines off nowhere, didn't see anything visually wrong.
So I open the radiator cap hoping I wouldn't see chocolate milk. Looks like green antifreeze, everything fine there.
Closed the radiator cap.
Pulled the dipstick out, oil on dipstick of course above level because the trucks running.
Look like it could use an oil change, oils pretty black. Put the dipstick back in place.
Next I decided to start pulling one spark plug wire at a time off the coil pack see if the motor would change the way it was running.
There was no change with each spark plug wire being removed from the coil pack one at a time.
However I did learn that one of my coils of the coil pack is not sending a signal out to one of the spark plug wires at all, so I'm running on five cylinders.
In the short time I've had this truck I've come to really like it and depend on it.
I was almost to tears when I called my brother and told him I think I blew my truck up, truck still running cuz I wanted him to hear it.
After I hung up with my brother I decided I was going to shut the truck off and see if it start back up.
So I did so, I shut the truck off counted to 10 and turn the key. The truck started right up and ran just the way it did before anything even happened to it.
At that point I got back out and did the spark plug wire removal test again to see if that same coil part of the coil pack was sending out a signal this time still no signal from that coil spot to the spark plug wire truck still running on 5 cylinders.
I decided I was going to drive to my brother's house to test the truck see if it would do the problem again.
So I slowly drove it to my brother's house. Truck still acting the way it has since the first time I've started it. Nothing wrong it seems like. Don't get me wrong the truck's got problems.
After I made it to my brothers I didn't even bother going in. I went ahead and drove towards the golden arches again to do this I was driving by my house. I decided to screw the golden arches I got hot dogs in the refrigerator so I parked at my house. Put four Big Red Smokies in the microwave, put the microwave on 2 minutes I'm now eating those as I'm writing this.
I do believe I now have a mystery on my hands.
Any help will be greatly appreciated!
Before anyone asks the " check engine " light has always come on and gone off multiple times as I'm driving the truck ever since the first time I got it to start. It never stays on for more than a whole minute.
I was in and out of my truck a lot today.
So driving my truck today I paid a lot more attention to when the " check engine " light comes on.
So about 95% of the time it comes on when I'm coming to a stop.
The other 5% it's when I'm taking off from a stop.
The light being on averages at about 24 seconds each time. That's counting in my head so the actual time maybe different.
I also paid closer attention to the RPMs at idle.
My average idle RPM is about 600.
When coming to a stop it goes down to around 400 or 450 RPMs then goes back up to around 600 RPMs.
I'm sure this plays a part in the " check engine " light coming on.
Sometimes it's around 700 RPMs.
Also today my gas gauge did a lot of moving.
When the truck is turned off the gas gauge is always at a 1/4 tank.
Most the time once I start the truck the gas gauge goes down to empty. But today it was going up before it would go down to empty.
The gauge was on full 7 times today.
It was at 3/4 tank 3 times today.
The gauge was at half full 8 times.
Each time however within about 1 mile after starting the truck the gauge goes down to empty once again.
I've not done any new work on the truck.
So I've not changed anything that would make new problems.
I just paid closer attention to the problems that already exist.
that rapidly changing fuel level is basically ruled out everything but the slosh module in my mind... that is the only component that will throw out higher/lower readings that actual unless you have both an intermittent short and intermittent open at the same time. Looks like you will be re-capping / replacing your anti-slosh module to me.
I agree Brain.
To be honest the problem I had last night is why I was paying so close attention to what my trucks doing.
I was almost in tears last night cuz I thought I'd blowed it up.
I edited Post #310 so the second to last sentence is easier to understand.
I think your rpms are dipping too low at stop - should be above 650 all the time.
That said, it could be genuinely your RPMS are that low, it could be your tach is off (I have decided mine is slightly off now) and just showing a little low.
If your RPMS are dropping too low I could see how that would cause the CEL to come on. No codes though?
I don't even know how to pull codes from any vehicle as old as my 94 truck.
With that said however don't the " check engine light ' need to stay on to give out codes?
Modern vehicles light the CEL for everything, old vehicles will set codes for everything but only illuminate the CEL rarely, so there definitely can be codes without a CEL.
How to on OBD 1 - paperclip method for those without an OBD1 scanner:
and what those codes mean:
Event Coverage
TRS Merch
