kegs85
ok so i pulled the half @%^ duraspark system and am puttin in the factory wiring harness from an 83 i picked up at the junk yard with a comp for 32 $.
now i'm tryin to figure out where do i plug the ignition coil wires into? i looked up the wiring diagram and i no it goes something called the solid state??? what the heck is this. If the previous person did put the different distributer on the truck will it still work?? i'm a little bit lost.
Thanks guys
