Ignition lock and door locks
Featured Build Threads
Yulee
FL - USA
Other
Mazda B2300
Drive
2.3L
Standard
I'm looking for a replacement kit that has an ignition lock and door lock cylinders keyed alike for a 1995 Mazda B2300. They seem to be available for a 1995 Ford Ranger and I have been told the two trucks are identical under the skin. But, I can only seem to find separate ignition and door locks looking for Mazda. then I will then need to get a locksmith to do some re-coding so all three will work with the same key.
Has anyone used the Ford Ranger lock kit on a Mazda.
Thank you
As I understand it, Ford built the trucks and sold them to Mazda to finish. The opposite arrangement from the Courier before the Ranger came out.
Lots of members have used Ranger parts on the Mazdas.
Thank you SenorNoob
Where did you happen to find a keyed alike set for a 95 ranger?
I'm looking for a set for my 94, (i assume the 95 set is the same?), all i can seem to find is door set, or ignition single.
I had to replace my door locks in my new to me B2.
I ended up adding remote power locks to address the different Door/Ignition keys.
Only need the door key if the battery or a door-lock motor dies.
Love the convenience of not having to use a key to open the door 😁
Featured Ranger Based Vehicle
