pintobobster
- Jun 30, 2014
- Age
- 65
- Washington State
- Automatic
ok so does not matter if moving or not I get a vibration coming through my steering wheel also can feel it through my feet no ABS light on dash at all all brake pad replaced, front rotors replaced, bugging the hell out of me I cannot find this vibration, I can be doing 50 MPH or 0 MPH and it does it at all times cold or warm or hot, NO steering issues no travel issues, (crab walk or bull dog walking) ONLY issue is that my speed control (cruise control) stooped working and I have been busting my balls over that too.....
no issues with speedometer no rough idles no other issues except stated......???
I can feel it vibrate the whole truck
ANYBODY else have/had this happening??
1995 Ford Ranger 4.0 Automatic 4X4 all wheel ABS
things I have done
replaced all pads
replaced ABS sensors in front
replace rotors and calipers
changed out sending unit top of brake cylinder (under hood)
bleed all brake cylinders with new dot brake fluid
front alignment
new tires (31x10.5x15)
replaced VSS
I am thinking ABS unit under the hood?? but brake pedal is fine no issues braking... no codes on dash no check brakes or check ABS....
AGAIN PLEASE ANY HELP
I am running out of shotgun shells.....
things I have done
replaced all pads
front alignment
replaced VSS
