if not the place for this post please help
pintobobster
Washington State
ok so does not matter if moving or not I get a vibration coming through my steering wheel also can feel it through my feet no ABS light on dash at all all brake pad replaced, front rotors replaced, bugging the hell out of me I cannot find this vibration, I can be doing 50 MPH or 0 MPH and it does it at all times cold or warm or hot, NO steering issues no travel issues, (crab walk or bull dog walking) ONLY issue is that my speed control (cruise control) stooped working and I have been busting my balls over that too.....
no issues with speedometer no rough idles no other issues except stated......???
I can feel it vibrate the whole truck
ANYBODY else have/had this happening??
1995 Ford Ranger 4.0 Automatic 4X4 all wheel ABS
things I have done
replaced all pads
replaced ABS sensors in front
replace rotors and calipers
changed out sending unit top of brake cylinder (under hood)
bleed all brake cylinders with new dot brake fluid
front alignment
new tires (31x10.5x15)
replaced VSS
I am thinking ABS unit under the hood?? but brake pedal is fine no issues braking... no codes on dash no check brakes or check ABS....
AGAIN PLEASE ANY HELP
I am running out of shotgun shells..... :icon_twisted:
Wheel bearings in the front?
Somehow front hub stuck engaged, and one or both of the outer U joints is kaput?
If you have a vibration while you are stationary, it has to be coming from the motor or something attached to it that is rotating while you are not moving, cooling fan for instance. Did you scan the computer to see if it has any codes?
I would do a tune up. All the money you have spent so far has been wasted. Brakes can only cause a vibration while moving. It sounds to me like you have a misfire or a bad engine mount. Possibly a bad harmonic balancer, but that is less likely because the 4.0 is internally balanced.
Some folks ass can "feel" vibration better than other folks can. So if you can then get friends to sit nest to you and ask them if they feel the same vibration.
Have you lost horsepower?
Is there a rpm range that shows more vibration?
Is there a particular SOUND to this vibration?
In short 99% of these complaints can be resolved with a tune up.
Big Jim
