hydraulich clutch line burned. how do I change
craigbreedlove
Parrish Fl
94 4x4 4.0 5 speed. the hydraulic hose from the slave cyl going up is burned against the exhaust. I have the tool to get the quick connect off. but where does the hose go to? I work at a hydraulic shop so getting the hose made is not a problem, unless there is something that I am missing. Please help me. tricks to change or anything.
The top end of the hose goes into the clutch master cylinder on the firewall. It fits into a hole at the back of the master and is held in place by a small roll pin that slides in right behind the collar on the end of the line.
Just use a small drill bit to push out/in the pin being sure not to lose it. It's real easy to do.
cocoa nailed it!
