HP gains after porting heads
Engines is goes vroom.
Taking all the replies into consideration it sounds like it's not worth it. I'm not racing the truck as it will be a daily driver. The engine (302 stock bottom, flat-top pistons, 270 cam, aluminum GT-40 heads, Ford Racing Roller Rockers, Trick Flow Trac-Heat upper and lower intake, Trick Flow 85mm TB) should make an estimated 400 HP. That's plenty for a daily driver.
I look at it as freeing up hp without adding gas to the fire.. but.. for a daily driver.. you'll be happy with what you have
