How can i get around my non-working 4X4?
02 ranger
Central Texas
In my truck the 4X4 is messed up, i know its the transfer case motor or the 4X4 control module but i dont want to blow 100 dollars yet. I have heard that you can get a pair of needle nose pliers and take off the cap of were the transfer case motor gear connects to the inside of the actual transfer case and their is a little slot were you can put the pliers and spin it. I was wondering is that when you are turning the gear how far do you have to go and can you feel when the transfer case is in hi or low?
:icon_hornsup:
if you take the t-case motor off its pretty straight forward, but you wouldnt want to go though all that before you go wheeling, you should just spend the money on a new motor
it's what i did after i coulsnt fix my electrical 4 wheel drive shifter.
and trust me, i tried everything and spent 900 dollars on it replacing everything including the GEM module.
the Borg Warner 1354 came in two options....Electric shift and Manual Shift. it is a direct bolt on replacement, and i was able to get one from the same year, and model ranger from a junkyard for 200.....250 with the shifter, linkage, plates, rubber boots for the cab...the bells and whistles really.
removed the front seats, tore up the carpet a little, installed the new transfer case and linkage and put the seats back in all in under 2 hours. never had a problem with the manual case since it went in!
hadto play with and adjust the linkage a little after but it works better than that crappy electric shifter i had.
