- Apr 13, 2008
- Fort Lauderdale
- State - Country
- FL - USA
- Drive
- 2WD
- 3.0 V6
- Tire Size
- P235/75R15
- My credo
- A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
When it comes to the Vulcan, as mounted in the Ranger, I'm liking the idea of a rear/remote-mount turbo, taking the place of the muffler, e.g. the STS style setup, sized/gated for 5-10PSI. (Consensus seems to be stock internals are good for 12+ psi--sans detonation!)
The long intake runner obviates an intercooler. Your airbox can be fed by the rear fender well just as easily as the current front fender well, eh? Underhood space stays at about same level of "crowding", or LESS. MPGs probably INcrease... if you can stay out of "ego boost", lol.
I wouldn't even bother running oil lines; i.e. besides the run-lengths involved, why run hot, increasingly dirty (combustion products, etc.) oil to your sensitive turbo? Not to mention adding potential leak points to your engine oil loop?
I'd just get a tiny 4" square oil cooler, a 1 pint reservoir bottle, hook up that 12V electric pump (delayed turn off after key-off?), pour in synthetic 0w-20, tuck it all up under the bed, perhaps behind a HINGED, drop-down skidplate, and let the turbo have its own closed CLEAN COOL lube loop! Probably go 50k+ miles between changes!
All ideas patent pending. ;')
