No problem Wicked. I'm no expert when it comes to turbocharging. I just figured that by making the engine more efficient at low boost, it would be safer and more reliable. I'd be afraid that increasing boost to compensate for other cheap mods would create heat and further increase the chance of detonation. Porting and polishing the heads and intake manifold would be a fairly cheap addition to the build. (Unless you hire someone to do the labor, then its not worth it IMO) And there's plenty of TB options for under $100. The roller rockers aren't needed I spose. Its something that can be added later.
Is it effective to run an intercooler with only 5-6psi? I saw a pretty neat setup on a supercharged 5.0L. If I remember, he brazed copper tubing to his "box" upper plenum. On the inside he had 1/4" fins running parallel with the throttle body flange from the front to the back of the manifold. Through the tubing he shot CO2 to chill the manifold. It was kinda cool and didn't look half bad, but I don't know how much real world gain that would be. Anyway, back onto the subject. Would a vulcan even touch 200rwhp with only 5-6psi?
