Help My Antilock brake light is on......
94DangerRanger
South Charleston,WV
Hey everyone,
I have a 1988 B2 and the antilock brake idoit light just came on and wont go off. Any ideas?Thanks:icon_confused:
my.php
[/URL][/IMG]
Well, one known place would be the connections at the control valve and at the battery. Maybe some cruddles are bunging up the connection? Also there is a separate ground wire run from that control box that goes to the negative terminal on the battery. Any bad connection there will also cause the light to come on. (found that out when I replaced the battery ends for new cables. Seems ford went a bit nuts on extra grounds and extra +12 feed lines.)
S-
