NID_FTL
- Oct 25, 2008
I have a 2.3L, 4 clynder in my 88 ranger and all of assuden 5 days ago wile I was driving about 35 40 miles an hour it started pinging and rough running and loss of power. wile it's running I can remover the 3rd clynder plug wire and it does not change the idle, however when I remove 1, 2 or 4 the engine stalls. I figured it was a bad injector so I replaced #3 still run's like crap. could this be a bad injector wire in the wireing harness or am I look at a valve problem or a blown head gasket? there is no water in the oil and the coolant is still not getting blow by so I am lost here. any help would be Helpful.
Other thing's I have done, is to verify the timming belt TDC marks, I replaced the fuel filter, and emptied the remainder of the fuel in the tank and replaced with fresh clean gas. I have checked spark on all 4, and inspected all the vacum lines. fuel pump is working and everything else I can think of has been checked. Help! Jimbo...
