- Oct 6, 2025
- Morton
- State - Country
- IL - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 4.0L
- Automatic
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- good question
Hello all, when I’m driving let’s say any temp above 90 degrees, and I stop and turn the truck off for 5 or so mins but less then 30-45 I’ll start the truck up and usually it will crank and start and die. Then I’ll crank it again and it will run but surge really bad and if I don’t hold it at 2000 plus rpm it will keep surging or die. Eventually after a few mins it will fizzle out and be okay. Seems to be worse with ac on. As well as the truck visibility hops like it will vibrate pretty bad. I am a younger kid so is this kind of just part of the older throttle body systems?
