Headlights and Foglights
Miramar
FL - USA
Vehicle
Drive
My headlights and foglights will not work simultaneously. It's either one or the other. Any ideas?
All the time? Or just when usung high beams?
Fog lights, from the factory, are wired to only work with low beam headlights on. The thought is that you shouldn't be using high beams in the fog because the reflect back in your eyes.
All the time.
Do they work if the high beams are on?
Stating the obvious here and you've probably already tried this, but the multi function switch or ground could be the issue. See if wiggling the stalk with just the headlights on causes any malfunction.
