Head light help
Is your axle joints, CV joints, leaking grease or do you have a leak at the differential where the axle seal is?
It's leaking oil since putting it in. The reason I changed it is after driving it a month all the grease spun out of the old one. Now I'm having to add gear oil to the diff
If I remember correctly, please correct me if I'm wrong, the axle slides into the differential.
The other style is they bold to a flange that goes into the the differential.
Either way, clean the diff off really good. This will allow you to see where it is leaking from. There are 4 seals total that will allow it to leak.
1. is the pinion seal, this is where the drive shaft enters the diff. Drive shaft comes from the transfer case.
2/3. 2x are the axle seals, one on each side.
4. is the diff cover. this can just be RTV so no gasket is needed. just a good cleaning and reapply RTV to seal it up.
Since this happened after the axle replacement my guess is the axle seal on that side needs to be replaced. It's not a hard job just time consuming.
alright i appreciate the help sorry for the confusion lol . I'm gonna take it to a garrage .
No problems here. Good luck with your new Ranger. Have a look in the Tech section for great information about your truck and how to's to fix things for yourself. You may come up with a few personal mod idea's browsing the tech section also.
here is a link for you: https://www.therangerstation.com/tech/
OK before you lose you mind I bought this a few months ago he said 1995 . The truck says 05 lol
You might want to update your profile from 1995 to 2005, that way future questions on the forum won't get you wrong answers.
