DisturbedMXer8
- Dec 7, 2009
- Anaheim, California
- 2.9 V6
- Automatic
I've looked through these forums and can't quite find any info on my current issue, so if anyone can help me out on this please let me know.
Here's the thing: I have intermittent power loss below 2.8k-3k RPM. What I mean by that, is that any time I apply more than 1/3 throttle or any time I add weight (eg. another person in the truck with me), it acts like it has less power. So, for example, I get on the throttle pretty good to get on the freeway at a good speed: once I get in third gear, around 40 MPH, from idle to around 2.8k RPM, it acts and sounds like it's choking, as if I were trying to tow 20,000 lbs with it (which I'm not). Then, the second it hits about 3k RPM, it instantly cleans right up.
I checked codes (KOEO, the whole deal), nothing. My first suspicion was the timing, however I recently had it checked and it's at spec. So later, I hooked it up to a scope and noticed the firing lines all over the place. So, I replaced the Distributor, cap and rotor, TFI Module, and the coil. Still have the problem. I really have no idea what else could cause this.
Here's the weirdest part... it sometimes gets better, sometimes gets worse. I used to be able to tow a 500lb trailer full of bikes, gas, and gear up hills no prob. Now it struggles with just a passenger riding with me.
Anyone have any ideas? Any help would be greatly appreciated.
Just to clarify, I've already changed plugs (and wires), air filter, fuel filter, and even replaced a pressure regulator that went bad on me. Like I said, any help would be greatly appreciated.
