Shran
Junk Collector
Solid Axle Swap
Truck of Month
What's the worst you've seen? Post pics
Here's my latest from yesterday. '93 Ranger I picked up very cheap, probably has a cracked head(s), typical milkshake oil, smokes a lot. I'm guessing this happened because the lower intake was leaking and the idiot tried to fix it first with a layer of what I assume to be JB Weld, then a coat of RTV smeared all over everything within a foot of the leak, then some sort of hard white stuff that kind of resembles sheetrock joint compound. Obviously it did not work.
