Hydro assist is perfectly legal.
X2
ASSIST is, full hydro is not
Sent from the road while ignoring traffic
I was pleasantly surprised at how well my truck handled with the 40's without assist.
I've got a PSC ram and a tapped box sitting in the garage waiting to go in....just trying to figure out what pump to run.
assist is mandatory imo opinion to run bigger then 37's on the street if you like to play hard on the weekend.
i like full hydro because i have broke sector shafts.
and assist makes good...depending on how your setup you could lose the sector and still steer.
verse reg steering like i still have. bust the sector and then your fawked....pure luck i didnt die or kill anybody else.
once you bust the pitman off theres no steering, so i cant see where full hydro is not safe at all. its creepy to drive...but if your rolling on 44's its better then a stock f350 setup. its made to take it if you build it to that end..
properly setup balanced assist is what i am saving for to cover it all
1400 bux not including the truss and welding. well worth it.
That is a valid point, however if you are driving on the street and your engine dies with full hydro you also have no steering. The reason I've heard is that with hydro assist there is still a mechanical link in case your engine dies.
Engines die more often than links break.
current vehicles on the market can steer themselves....how the fawk is that safe if it goes haywire? sucks that a car as delivered can now be remotely driven with your ass in it off of a bridge.....lock ya in and run ya off. weeee gone before ya know what happened. think about that for a minute.
are you bullying me?Only if you wanna be.
It provides a tried and proven framework for implementing a systematic approach to managing an organization’s quality processes to meet and exceed customer requirements.
It provides a way to make a systematic way to manage more ways to meet requirements? Uhh... (By this definition I would assume ISO is like a big universal remote. It makes stuff more betterer by streamlining everything and everybody is cool with using it.)
and i am talking street use too.
a properly constructed system will have a "tight" and for road use ideally a feedback type steering control valve...
...regardless if its getting force fed and fills the cylinder on whatever side the wheel is getting cranked causing the ram to steer that direction.
the pump-like thing works even without power. It's probably awful, but it works.
just like your brakes you push they push. just like the oil pump on your engine....it turns it pumps
If you lose power brakes you still have brakes. If you lose powered hydro you still have hydro. Makes sense...
theres looser valves that are less efficient which is what a normal steering gear would be similar too and some types of steering control units that wont work at all with no power due to solo design etc.
Buy a good pump-thingy that works if you lose power. K.
buying the proper tool for the job is key. No. Hammers work for errything.
