Is high steer like those blocks that go on top of the flat top knuckles ? I don't have flat top knuckles , what now? Buy flat top knuckles but can I still use disk brakes?
Reid knuckles are nice, they are already machined for highsteer and will accept all the Ford hardware. I know Ford 3/4 knuckles wont clear 1/2 ton calipers, so double check the Reids to see if they are 3/4 or 1/2.
If you do a search or just take few hours to read through some SAS builds on here you can answer 99% of your questions. Every build is a little different, but you should expect that when using junkyard parts to redesign a front suspension. People have used different axles, knuckles, coils, arms, etc. You can pull info from all the builds and take all of it into consideration when building your own.
-PlumCrazy
you just have to plan it out. i've been planning mine for around 2 years now, still havent fully determined what gear box to use. I found a guy on craigslist around me with a set of new Reid knuckles for 225.
I'm also thinking of going hydro assist steering. Not %100 sure if its legal on the streets tho
