- Sep 26, 2009
- west virginia
vent system...definately
You have a spider web in your canister vent tube. Find the vent valve, pull the last section of line off, the one that is just open on one end, and then either blow thru it with compressed air, or find a 1/4 in ball bearing and drop it thru. I work for a dealership service dept and this is a VERY common issue especially, right at the start of summer.
My truck does it at some stations when i stick the nosel all the way in, if i pull it out a little it will pump fine
i guess i am the only person that knows this.... but you aren't supposed to put the pump on full blast. you are wasting money. its like a sink if you put it on full blast you are getting mostly air. so if you like paying for 50% air and 50% gas lol keep blasting away.
i guess i am the only person that knows this.... but you aren't supposed to put the pump on full blast. you are wasting money. its like a sink if you put it on full blast you are getting mostly air. so if you like paying for 50% air and 50% gas lol keep blasting away. but i put mine on the lowest setting i can when filling up. i still get like 20 gallons in my tank in about 5-10 mins. and it will probably fix your shutting off problem
As a gas station manager, I'll tell you that is 100% WRONG.
The state tests multiple flow rates when the do the weights and measure certification to make sure the dispensers are within spec and have not been tampered with. They also check each grade the dispenser dispenses at different flow rates.
well then the guy from the gas truck gave wrong info then.
