2.0L ('83-'88) Worn throttle shaft 1 bbl E37E FB 2.0L advice please
Derekzee
5+ Year Member
Ontario canada
Just looking for the best advice please to fix thid vacuum leak.
- buy new Amazon cheap carb?
- rebuild my current carb and drill out the shaft and add bushings? Does anyone know where I can get these?
- I have found another old carb E5ZE AB with a solid throttle shaft. Either rebuild this carb, or bolt this throttle plate to my current carb? The only difference I see with the old carb is that it has a wiring harness coming off the throttle shaft, my carb does not.
See pics, my current carb is the cleaner one. Thanks in advance.
  • Worn throttle shaft 1 bbl E37E FB 2.0L advice please
The simplest would be to swap the throttle bodies that you have. But they may not swap, it sounds like one was a electronic carb and the other is not.
2nd solution I would do is buy a china knock-off. Unless you have access to a machine shop and the time to do it, it's just not worth re-bushing the carb unless it was not available cheap, which it is apparently since you mentioned it.
