rt520
- Jan 20, 2014
My fuel pump is not turning on. Truck is a 94 B4000 4x4 extended cab
Here is what I've done so far.
I tripped and reset my inertia switch.
I checked the 20amp fuse.
I took a voltage reading at the wire harness at the pump. 9.4 volts
I took a power probe and hooked it up to the pump, it turned on.
I pulled out the fuel pump relay and put the power probe in #30 that goes to the fuel pump and was able to run the pump.
#85 on the relay gave me a volt reading of 0.4
#86 gave me 11.9
#87Wa didn't read anything.
Any suggestions on where to go from here? I was thinking about going out and buying a new power relay and fuel pump relay and seeing it that does anything.
#86 gave me 11.9
