1v6pony
- Dec 5, 2007
Detail Info:
Ok I have been tring to find out why my fuel supply line blew off due to presure,it also will not run. What I found out ,thier is no return fuel going back to the tank, and I do not see any fuel in any of the rails or any presure in the reliefe valve...
What I did was take of the fuel presure regualtor and attached it to the supply line directly from the fuel pump. fuel comes out ,the out put side of the regulator so it does not seam to be the culprit. I ran a small plastic zip tie down the fuel presure reliev port and down the plate from the input side it does not seam to be cloged....I also ran the pump with out the regualtor attached and fuel sprayed out , so that line does not seam to be cloged... What is the trouble with this, What do you think it could be?????Am I missing something??? Is thier some kind of extra valve in the fuel rail???
PS: I can not pull codes on this as this is a engine swap to a rock crawler
I have a rock crawl meet this weekend and I need this diagnosed. Thanks Brad
