fuel lines
Featured Build Threads
greenstranger89
Can i run my stock fuelines and barbs from a 89 2.3 motor to a carb 5.0 swap or are they to small and i have a return style regulator. Or is there a way to get bigger bars like 3/8" to match up with my regulator? pictures would be great!
i would upgrade the whole system. then if you are having a problem you dont have to tear it back apart to replace all the lines and pump.
is your 5.0 carbed?
yes it is carbed i have the proper regulator bit is 1/4" line big enough to flow enough fuel?
And does anyone know about the wiring color code for the fuel pump im gunna run it to a 12v accesorie when the key is on accersoory cranking and running
Event Coverage
Featured Ranger Based Vehicle
