Fuel efficient exhaust size?
Isk Stark
The HillBilly
2.3 (4 Cylinder)
Total Drop
5"
For the D-tec 2.3L (I'm guessing that's what I have since mine is an '02), what is the stock tubing? 2"? What did everyone have luck with?
When I had the KA24DE (Nissan 2.4L truck engine), I had luck with a 2.5" cat-back.
I'd like to hear some discussion on the pluses and minuses of differing exhaust sizes and set-ups.
IE:
"I prefer a 2.25" exhaust to retain some back pressure."
"Route the exhaust all the way to the back for this and this reason"
"Dump the exhaust before the rear axle because this."
Stuff like that. I will be incorporating a Flow-40. My set-up is for fuel efficiency.
This is a bit misleading. Any backpressure is bad. What you want is to get the exhaust gas velocity as fast as possible for the desired RPM. I am not sure what size Ford used when designing the exhaust for the 2.3 Duratec, but I imagine they chose a size/length that was a good compromise to get both power and efficiency based on the power band of the 2.3.
I did a cut & paste (from his cut & paste) from jbranney, regarding backpressure, from another forum. Here is his response, which is summed up pretty well:
"There is a common misconception that engines need backpressure in order to run properly, generate low end torque, etc. That is simply untrue. Backpressure is a bad thing. Always. Take a look at a top fuel dragster...how much backpressure do you think those zoomie headers make? Very little, and those engines produce 6500 hp.
So, what is backpressure? Any fluid flowing through a pipe experiences drag on the walls of the pipe. This depends on a number of factors, including the diameter of the pipe, the smoothness of the inside of the pipe, the viscosity of the fluid, and the velocity of the fluid. This drag results in a pressure drop through the pipe. In order for the fluid to flow at all, the pressure on one end of the pipe must be higher than at the other. In an exhaust system, that pressure drop is what we refer to as backpressure. It's pretty obvious that the engine has to produce this pressure differential, so the less power it has to spend making pressure to push the exhaust out, the more power it can send to the wheels.
Given that exhaust pipes are pretty smooth, and that we can't change the viscosity (thickness) of the waste gas being forced through the pipes, we are left with basically 2 parameters we can have any control over: The pipe diameter and the gas velocity.
Unfortunately, the pipe diameter controls the gas velocity since the volume of gas is prescribed by the engine. So, we really only have one thing we can change. So, bigger pipes allow less pressure drop for a given volume of gas because the velocity is lower. The pressure drop (backpressure increase) is proportional the gas velocity squared, so if I double the gas velocity (by reducing the cross sectional area of the exhaust pipe by half) then I quadruple the pressure drop.
Well, there's an easy solution for that: Just make the exhaust pipe bigger. Bigger pipe, lower gas velocity, less pressure drop, so less backpressure. Wow, that was easy. After all, this is the way it's done for basically any type of commercial plumbing system. Need less pressure drop on a chilled water pipe or a natural gas line? Just make the pipe bigger.
But wait, there's a problem....Having a huge exhaust pipe has killed my low end torque!!! What's different? Oh, there's no backpressure!! Therefore backpressure makes torque!
Wrong.
An exhaust system is different than just about any other plumbing situation. How? Because the flow is pulsed, and this turns out to be a big deal. Every time a pulse of exhaust gas runs through the pipe, a strange thing happens: it as it passes, it has a little area of vacuum behind it. Just like a NASCAR stocker running around the track, the pulse generates a little bit of a vacuum behind it. In NASCAR, a driver can take advantage of another driver's vacuum by getting right behind him and driving in it. The wind resistance is drastically reduced. This is called drafting.
Well, how big the vacuum behind each pules is depends on the gas velocity. The higher the velocity, the bigger the vacuum the pulse has behind it.
Now, this means that I can "draft" the next pulse, just like in NASCAR. In NASCAR, it's called drafting, in an exhaust system, it's called scavenging. You've probably seen this term used when talking about headers, but the same concept applies in the pipe.
I get the maximum scavenging effect if the gas velocity is high, so the pipe needs to be small. By maximizing the scavenging effect, I help to pull pulses out of the combustion chamber, which means the engine doesn't have to work as hard to do that.
This has the most effect when there's a bunch of time between pulses...in other words, at low rpm. As the revs rise, the pulsed flow becomes more and more like constant flow, and the scavenging effect is diminished.
So, at low rpm I need a small pipe to maximize scavenging, and at high rpm I need a big pipe to minimize pressure drop. My exhaust pipe can only be one size, so it's a compromise. For a given engine, one pipe diameter will make the most overall power (i.e., have the largest area under the curve on a dyno chart).
So, the loss of torque has nothing to do with backpressure, and everything to do with gas velocity. So you need exhaust components that are not restricive (manifolds/headers, mufflers) and that are sized correctly for your application.
To further dispel the "backpressure is necessary" theory, try this if you want. If you have access to a vehicle with open headers, make a block off plate that will bolt to the collector. This plate should have only a 1" hole in it for the exhaust to flow through. That will give you PLENTY of backpressure, and zero scavenging. Then you can report back on how much low end power it has.
The one exception to sizing an exhaust is for turbo cars. Since the turbo is in the exaust stream, the gas flow spinning the impeller tends to come out of the turbo with the pulses greatly diminished. In this case, you can get away with running a larger pipe than on an equivalent HP N/A engine because you can't take as much advantage of the scavenging effect."
Black BII, I am not starting a flame war. However, I disagree and will argue that SOME backpressure is good.
However, the rest of it I fully agree with. Ford chose the optimum exhaust diameter for efficiency already.
Over the years, I've read that people have not had much luck anything over 2.5", and even that is for the 4.0L SOHC and OHV motors.
The 2.3L are not made for power, and doing anything significant to increase that would be like polishing a turd for minimal results vs your time & money spent. It's not to say that you can't turbocharge it or go crazy and make good economy and power, but, it's generally not worth your effort.
I have my exhaust now dumped under my bed (after my tailpipe got squished), and nothing was affected.
Flowmaster 40's sound good, and are a frequently used muffler for our trucks. Good flow numbers, and no decrease/increase (increase: without additional power adders)in performance.
For the low 2300 RPM power band and shifting, stock tubing should suffice.
Regarding your exhaust pipe diameter: go out and measure it. Don't expect people to go out and measure their exhaust if you haven't done your own legwork first.
The terminology is misleading. When hitting resistance, airflow will slow down, however the flow is still going in the same direction. So when someone says they need more backpressure, I make sure to point out that no, backpressure in it's literal meaning is not what they want in order to help them understand that resistance is what they want(in the form of the correctly sized pipe), and not actual 'backpressure'.
https://www.dieselnet.com/tech/diesel_exh_pres.php
Pretty much, too much back pressure results in a choking engine; too little back pressure is good scavenging but causes poor economy at the exhaust valve/combustion chamber level which could vary depending on the current operating temperature and RPM of the engine.
keep going fellas, you haven't discussed reversion yet.
IE:
what's your MPGs now? what kind of tires? loaded or empty? bed cap or cover?
what speed do you usually drive at? hilly or flat terrain?
It's a 2.25" stock piping, so I will stick with that, but replace the muffler with Flowmaster.
What's the verdict on dumping the exhaust before the rear axle to save weight? Is it just a sound issue?
not sure on that.
my '05 gets 28-29 on the freeway. still on the factory exhaust system at 327,400 miles.
Turns out stock 2.3L piping is 2 and 1/8 or something odd like that. Stuck a Thrush Rattler 2.25" turned down just before the axle. Cut the stock resonator off as well.
Truck sounds so ricey. I love it.
