Fuel and Temp Guage
Nate.Mountain
Idaho Falls, ID
Hello all,
Quick question...so something is up with my fuel level guage and temperature guage. Majority of the time nether of them work. But every once in a blue moon the will both work. I figure it is a bad ground. Anyone know where that is located? Since they work and dont work together i figure its not the sending unit.
Thanks for the help
Nate
Ignition switch? odd one, how did you figure that out?
I was going to say it probably wasnt the ground I was going to say the connector on the guage cluster suspect. Each one of the sending units provide the grounds for the guages. They share the same power supply a voltage regulator that puts out around 8 volts pulsing voltage yea from the ignition switch to the regulator.
So why just the two gauges, wouldn't it affect all the gauges and anything else that it powers?
well i figured it was the ignition switch becasue if i wiggle the key around some the guages will kick on and off
