- Aug 10, 2014
- Age
- 33
- Madison, IN
- 4.0 V6
- Automatic
- Tire Size
- 215/70R15
I seem to have developed some wheel bearing noise at 45-60mph. It's gotten worse over time... it started acting up on a 2500 mile trek to Colorado back in July; the most recent drive with it, it was pretty loud. When it was aligned last fall, I was told the front bearings were a hair loose, and lazy butt here didn't bother confirming the bearing nuts
... suffice to say I likely need do wheel bearings on the front.
They rotors (and bearings) were replaced as part of a full front brake job in late 2017 (almost 5 years ago). My question I'm pondering is if it's worth it to replace the rotors while I'm at it as it'd make the repair easier (no need to remove/install outer bearing races) and rotors aren't terribly expensive. I haven't had any front brake issues though... maybe an opportunity to upgrade to drilled and/or slotted rotors?
