- Sep 30, 2007
- Age
- 48
- Manual
Hey man,I noticed that ya had extended brake lines after ya put the springs on with the leveling kit.I'm trying yo figure up some numbers to see what it'll cost me to do a 3-4 inch rough country lift on my 94,which is pretty much the same as yours except it has the 4.0 in it.The kit I'm looking at is saying that I'll pick up 3 inches all the way around and it includes everything but the shocks and brake lines.Where did you purchase yours at and how much did they run you?Would you think they'd be long enough for the lift I'm looking at?I have found a pair that are made by skyjacker but I don't know if they'll work since there saying they won't work with ABS which my truck has.
I might be jumping in to someone else's thread here, but..
The extended brake lines from skyjacker are for the front wheel brakes, and your '94 does not have front ABS, only rear. You'll definetly need to upgrade to extended lines if you're going for a 4 inch lift man.
Maybe you should open a thread in the suspensions section, that'll give input from more people
