Ford Ranger Pursuit
Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS Banner 2012-2015
GMRS Radio License
TRS 25th Anniversary
Nocona
TX - USA
Other
2005 Jaguar XJ8
Vehicle
Drive
2.3 EcoBoost
3.5-inches
70763
70764
Top Gear decided to create a rendering of a low slung mid size muscle truck based on the Ford Ranger.
Up front, it features a larger grille, a more aggressive bumper with a bigger intake, and a front splitter. The aluminum hood gets a central heat extractor. Moving to the sides, there are wider blistered fenders and side skirts, as well as enlarged functional vents on the fenders. At the rear, you’ll find a sports-bar-mounted spoiler and body-colored bumpers with cutouts for the dual exhaust tips. Our sports truck comes equipped with 20-inch alloy wheels shod with 275/45 tires.
The truck is powered by a tuned 3.0-liter twin-turbo EcoBoost V6 engine that puts out 434hp and 610Nm of torque via a 10-speed automatic transmission. It comes with an Intelligent 4WD system similar to what you would find on an Explorer ST. This should enable our high-performance Ranger to accelerate from 0-100kph in under 5sec. Top speed is electronically limited to 230kph. The next-gen Ranger’s T6.2 chassis can accommodate electrification, so there’s room for an even hotter 494hp EcoBoost V6 Plug-in hybrid variant.
Underpinning this is a lowered sports-tuned suspension that consists of modified independent double-wishbones up front and a five-link live-axle coil-spring set up in the rear. All corners get larger disc brakes with red calipers.
Since the Ranger was developed in Australia, they decided to call it ‘Pursuit,’ a name once used by the Australian Ford Performance Vehicles version of the Falcon ute.
If Ford would build our Ranger Pursuit, would you consider it?
The mini truck crowd will probably like it. Not to my taste though.
Dayum.
Yeah.....that is a whip.
I'd be happier with a reg cab short bed.. without all the God awful styling of that monstrosity.
Hell yeah I'd consider it. It basically what I've been asking/wishing for. 🍆
I like the body work, would definitely look better in a single cab.
Looks better the current ranger at any rate.
Other that some body panel changes, it does look like not much has changed.
i think it looks great but i am sport car person. if i could lower my ranger, i would, and put huge sway bars with sticky tires and have a blast at the autocross.
Looks like the old Sport Trac adrenaline.
Doesn't look bad but it doesn't do much I need a truck to do.
