it has a 2.9 btw, but i would agree with ignition miss but i have tuned the motor, checked time, and the motor runs quite well. It just has a "shaking" that vibrates when you are at 1200 to 1800 rpms. I have timed the motor to 12 degrees and had it at 10 with no change. The vaccuum i believe was at 17 pounds on the gauge and i have checked every line and sprayed carb cleaner all around the intake. I even thought the vibration might be caused by mounts so I changed all those to. I changed the tps and set it to .95 with a volt meter. I really just dont know what to do now. Thought maybe it was a weight or balance issue since the problem started by hitting a large hole in the road at 55 mph. Also, would the clutch weight you are talking about AllenD have an effect on the truck sitting still in neutral? How would a cracked flywheel act? It just really feels like something is out of balance, and btw, it doesnt do this at dead idle, it only does it when you first touch the gas, but i have changed everything electrical and in the ignition, the truck is not missing.
