Factory Satellite Radio Antenna
Buckeyeman
ASE Certified Tech
Summerdale, AL
2.3 (4 Cylinder)
Does anyone know if you can use the factory satellite radio antenna on a 2010 Ranger with a Sirius Dock & Play unit without adding another magnetic antenna to the roof?
Which was what i think he was asking
I found the Sirius module behind the glove box and unplugged the wire from the roof mounted antenna and it will plug into the Dock & Play. The only problem is it isn't long enough to reach. I need an extension cable with a female connection on one end and a male 45 degree on the other end.
How are the OEM antennas mounted? Are they magnetic as well? If so, can you completely pull the antenna and reposition it somewhere that will give you enough cable to run where you want? Not sure if this would leave you with a hole. As an FYI, I have mine (not OEM) in the car sitting on the dash at the windshield (both the Ranger and the Mazda6) Less noticible to thieves.
If that is not an option, you can get extention cables at Best Buy (or cheaper online). All I have seen are 50 ft though.
it will work just fine i have my sirius dock and play on it if u need more cable buy and extension i mounted mine in the glove boxand just control it with my aftermarket cd player
I ordered a extension cable from TSS Radio, and now I can use the factory antenna. The Sirius P/N is 14130 for the 20' cable with two different size male connectors on each end. It works, although I only needed about 3' extension.
I FINALLY found a antenna extension cable that works with the factory satellite radio antenna. If anyone here that uses a dock & play satellite radio and wants to use the factory antenna here is the place to go, www.myradiostore.com and order the Vehicle Factory Single Lead Antenna to Sirius/XM Adaptor item #243-3507 for $29.99. It works perfect.
You sir, are awesome. Old thread sure, but very informative. Should be in the tech library.
I am actually working on my stereo and have the factory Sat Radio. I just installed the Pioneer DEHX7500S and ordered the Sat Radio Tuner for it. I had to order a XM Antenna Kit from Terk just for the adapter to use my existing antenna.
I also ordered 2 pair of Rockford Fosgate Prime 6x8s, a RF Punch P3SD4-10, and a RF Prime R250X1 Amp.
