F150 question
Yes the 4 doors (rear suicides) are very nice to have, Mazda has them, XLT doesn't... I live with it, but if I got another truck I'd like them.
I'm confused again about towing on my '97 XLT. I believe my Gross Vehicle Weight Rating is 4920 lbs. As I understand it this is how much the truck can weigh fully loaded.
Then my user booklet says GCWR (combined weight rating) is 9,500 lbs for my engine and axle ratio and model. Max trailer weight is 5,600 lbs.
So I am supposed to take my GVWR and subtract actual curb weight (by weighing) to find available capacity what the vehicle itself can carry. Curb weight being stock vehicle with nothing in it.
Likewise I take GCWR and subtract actual weight (without trailer) to find out how much I can tow in trailer weight.
Not knowing curb weight right now, just for example say it's 3500. That means I can carry 1,420 lbs of passengers, tool box, anything added. Let's say I have 300 lbs of passengers and 300 lbs of other stuff.
Using these example number, now my loaded weight is 4,100. That's my "gross vehicle weight". To find available tow capacity, I take 9,500 less 4,100 to get 5,400. This is under the max trailer weight.
Now I know I don't want to be maxing everything out, but unless I screwed up somewhere, in this exqample, it seems like I could tow an open car trailer with a light car on it. I'm saying, if the trailer weights 2,000 lgs and the car weighs 2,400 lbs, I'm towing 4,400 lbs which is 1,000 lbs under max so it should be ok. But eveything I've heard here says no you can't tow a car trailer with it.
I am missing one important piece of info and that is what does my truck weigh (gross vehicle weight) with 2 passengers and whatever I normally carry in it. So I'd have to find a scale or get a set of 4 wheel scales (probably expensive).
There are fine points about front and rear reserves. Like, you can't put a plow on the front. Trailer tongue weight might come into it but I'd think usually they are balanced pretty much.
What am I missing? (besides not knowing gross curb weight). Even if my gross curb weight is 3,900 I'm still ok according to the numbers.
Edit: Truck scale is 15 miles away I go past it on way to vet. It's for weighing the big semis but it should be able to weigh the Ranger, right? Looks like maybe $15 to do it - worth it.
While you basic thinking is correct, pay attention to the max tow weight for your specific truck configuration. While the truck itself might be able to handle the load, the brakes and/or transmission might not.
This is why the Rangers with a manual transmission have a lower tow limit than those equipped with an automatic transmission. The devil is in the details and you don’t pay attention to the details, it could go bad.
Plus, if the insurance company catches wind of it, due to an accident, they may deny your claim. Not to mention there may be some sort of ticket or legal action from the responding police officer(s).
Right, it all has to be w/in limits.
I was reading in the user booket and it has more info that may help completing my door sticker info.
The first thing I ran into is the user booklet doesn't list R6 axle code in the booklet (8.8" Traction-Lok). But the shop manual does list it, so I'm pretty sure R6 would be correct and it was just omitted from the booklet in error. F6 is the 7.7" and mine is 8.8" and it's listed in the shop manual. All the axle codes regardless of ratio or size have the same rating, 2,750 lbs, so I'd say I'm safe to call the Rear Gross to be 2,750. Check off one more known item.
What I am missing then is Front Gross and the reserve weights (Front and Total).
Here's how I believe these can be determined:
The Total Reserve is how much you can load into the truck, distributed correctly, AFTER you account for 150lb passengers in ALL seating positions. I'd assume that if you have bench seat and it has three seat belts, that means five passengers (750 lbs) and if you have bucket seats like I do, it's four passengers (600 lbs).
My Gross Vehicle Weight is 4,920 (this is known from Oasis and from Ford). Subtract 600 = 4,320. From this you'd have to subtract curb weight (includes full tank gas, jack, spare, user booklets, nothing else - just as it came from the factory). The only way you will know curb weight is to weigh the truck, which is perfectly do-able, and I have to believe they weigh it at the factory to get these numbers because it will vary depending on the options and model. For this weight you want the total truck weight not per axle.
Let's say for example the truck weighs in at 3,900 lbs (a guess, for the example). Then the Total Reserve woud be 4,920 less 3900 less 600 = 420 lbs that can be loaded, properly distributed, and not exceed GVWR. Now they may have a safety margin in there, but if they do a strict calculation that should be the number. For trucks that have 5 seating positions, it would be 150 lbs less (so 270 lbs) and those number seem to be in the range you usually see for Total Reserve.
Front Reserve is something else. For this, first you need the Gross for the front axle, this I'm missing. Usually you see Front Reserve small like under 100 lbs so we'd expect it to be in that range.
Here's how I would approach this:
Having weighed the truck you already know the Total Reserve. But you don't know how the weight is distributed front/rear. Weighing it per axle, which you can do, tells you something, but it doesn't tell you how the weight is distributed with passengers. I don't know how you would determine this short of adding 150 lbs to each seat position then weighing it per axle. Someone who has worked in the assembly line could probably tell me how they do it. Anyway, if you do this, then you will get the Front Reserve (you have to know Gross Front, and subtract the front weight you get from the scale) and it's usually quite small which says if you are running with all passengers you can't add much to the front axle weight. There is no such thing (on the sticker) as Rear Reserve but I suppose in theory it would be Total reserve less Front Reserve (maybe). It's not required, so, moot point.
That's why when you look at Reserve weights they are always some odd number that you cannot figure out by looking at axle weights or gross weights. It is just going to depend on the curb weight which can vary all over the place and it's possible that they (Ford) just knows that for specific axles when you add x lbs for passengers, this is how it affect the front/rear weights.
In the user booklet they say, weigh the axles separately. Also weigh the truck total. Also weigh the truck and trailer together. None of these number should exceed the ratings, after you have added in for your passenger and cargo weights.
I think I'm getting close to being able to reconstruct the sticker. All I need is the Front Axle Gross and I suspect it's the same for all '97 4x4 trucks with 4.0L. I don't know if they had different front springs. My truck has the 2" blocks oem in the rear to account for the 31" tires oem (ok, 265/75, but same size) but do they also raise the front, I don't know, and would it affect front axle rating, I don't know.
Long slog, but I think by getting the curb weight with and without passenger weight, total weight and per axle, I should be able to accurately state the total reserve weight and if I know the front axle gross I can know the front axle reserve and those reserves should be at least as accurate as the factory numbers maybe even more so. Reserve weights are just a guide that say, -if- you fully load with 150lb passengers, this is how much you have left for cargo. If you normally run with 2 passengers and you know their weights, then you will know how much additional weight you can carry and if you load it reasonably distributed, probably you will not exceed the front or rear ratings, but you'd have to weigh it loaded to know that for sure.
My gut tells me, you don't want to load a 26 year old truck to the max or tow to the max. You can't load the truck to max (4,920) -and- max out the trailer (5,600) because you will exceed the Combined rating of 9,500. But you can probably run the truck with 2 passengers, not much else, and max the trailer (in theory). I'd think it wise to stay maybe 10% under max for the trailer (say 5,000 lbs).
Note that the average man weights197 lbs and the average woman weighs 170 lbs so the 150lbs they use is just a benchmark number probably assuming you are not carrying 4 or 5 men 200 lbs each. Obviously if you do then you have to factor this into your calculations.
The upshot of all this is, if it's in fact true that I could tow 5k lbs (safely), then if the car I want to trailer is 2,400 lbs, that leaves me (safely) 2,600 lbs for the trailer, and I think you can get a decent trailer that weighs in at less than 2,600 lbs or around there. It doesn't leave much room for spares, tools, etc, but you could do it. Admittedly if it's something you do a lot, you probably want a different truck (thus this thread) but if it's an occasional thing, I am theorizing you could do it (and I see others have done it). So maybe, while it might be nice to have an F-series, I don't think I can make a strong case that I will necessarily have to have one.
Open to comments. And suggestions, like, where do I find my truck's Font Axle rating? Still hoping to find it in shop manual, but not so far. It would be helpful to look at several '97 4x4 4.0L stickers and see if they are all the same that would lead me to believe mine is that. So for those of you with that truck, if you can post the Front rating (don't need the whole sticker) that would be very helpful. Your Rear axle rating for this truck should always be 2,750. Once I have that I think I can put this to bed and print out a new sticker (meaning, there are lots of places that will print it for you if they have the info).
I'm holding off doing the weighing for the moment hoping I can get my truck's Front axle rating. As to the tool box, I guess I'd take it out to get the numbers for the sticker. Then I'd weigh it and add back to get my normal curb weight. I think I could weigh it by two people on two scales with and without holding the box. Or just another trip to the scale, not hard to do.
I'm not worried about misleading anyone with wrong Reserve weights. First of all, they're guides only and remember they assume fully packed with 150 lb passengers which isn't probably the usual situation so they don't come into play except in theory because you will always weigh the truck front/rear and total if you are concerned you are maxing it. Secondly, the number I get will be accurate as the truck stands and the only way they could differ from factory oem sticker is if there is a safety margin in there. But you know they have to be small, front usually about 100 or so and rear in the small hundreds so if you get a number much different then something is amiss.
Still searching on web for front axle rating, I find lots of charts on other sites that list front axle ratings but I can't find it for 4x4 Supercab 4.0L.
TRS chart says 3,197 for curb weight. That seems low. I think it would have to vary by engine.
Ford Ranger Dimensions - The Ranger Station
Sales brochure indicates I have Payload Package#1 (Standard) which is 4,920 gross so that checks against the other info I have. Payload Package#2 (optional) would be 5,100, so that's really not adding much (180 lbs). I don't know how they accomplish this, it must be heavier front springs because the Rear axle gross is always the same according to the shop manual.
4.0L was optional, it has 35% more torque than the 3.0L. You do notice the difference.
Is the 2000 Triton a good engine? I like the looks of this vintage ok and they are a lot cheaper, I can find some low miles ones red supercab. I like the stepside I think it makes the bed a little wider.
Edit: I see the triton is 5.4L so wondering if that is the same as the later 5.4L or is it better.
The 5.4 2 valve engine is supposed to be good. The 5.4 3 valve engines are awful and should be avoided.
All trailers with relatively central axles (as opposed to a tractor trailer type trailer with axles in the rear) should be mounted where 60% of the weight is in front of the centerpoint of the axles and 40% of the weight is in the rear of the center of the axles. If too much weight is behind the axle, it actually pulls up on the hitch, and it can start a harmonic imbalance (the oscillating).
If you stayed at a constant speed, the oscillating would stay even. Of course everyone’s first thought is to slow down, and when the trailer is oscillating, the more you slow it down, the faster it will oscillate. If you’re ever in that situation, while there is no good option, perhaps the best of the bad options is to immediately start slowing the rig, but do it slowly. Whatever you do, don’t try to go faster assuming that the trailer will trail the truck in a straight line and it will center. The oscillation is excess energy, and the faster you go, the more the energy, the more violent the isolation. Hopefully the trailer settles down. Obviously the best solution, is to load the trailer properly in the first place.
As a young bonehead, I actually went through this once with a load of firewood. It was a little trailer behind a Pinto squire station wagon. Fortunately, I was able to stop and restack the wood. It’s not a situation you would want to repeat!!
Hope it helps.
To instantly stop the oscillation, do not touch the truck's brakes, reach down and manually apply the trailer brakes. It will straighten right up. That is why according to federal rules, surge brakes are illegal, there is no way to apply the trailer brakes separately from the tow vehicle's brakes. But of course a lot of boat trailers have surge brakes as well as all u-haul trailers.
I think you're over thinking it, to be honest. All you really need to know is this:
  1. GVWR
    1. Gross Vehicle Weight Rating is the maximum weight your vehicle is rated for, including vehicle, accessories, cargo and passengers
  2. GCWR
    1. Gross Combined Weight Rating is the same as GVWR, except includes trailer and trailer cargo
  3. GAWR
    1. Gross Axle Weight Rating is the maximum weight each axle is rated for. This should be consistent across all configurations that use a given axle.
  4. Maximum Payload
    1. This is the MAXIMUM cargo capacity including all cargo and passengers stowed on the vehicle itself. If your payload is, say 1/2 ton, then your passengers and cargo can not exceed 1/2 ton. This is why the Ranger's minimum payload is 1250. 1,000 pounds cargo plus 250 for the driver.
Nothing else really matters, including reserve weight. Reserve weight, by my guess, is a buffer, maybe 250 pounds, that they reduce the actual weight ratings by 250 pounds to give you a margin for error. Again, it doesn't matter, because you're not supposed to go over the ratings listed above, even if they are 250 pounds less than the actual maximum.
Yes it's just the front axle rating I'm missing. (your #3, there are two numbers, front and rear, I have the rear, not the front yet). Rear is actually the same no matter what axle you are running, seems odd, but that's the way it is. Adding payload package doesn't change the axle rating, so go figure. Kind of makes sense.... stronger springs don't make a stronger rear axle, and changing the differential doesn't change it if the axles themselves don't change. (Kind of guessing here, but it would make sense).
The actual max payload is just going to be whatever is left when you subtract curb weight from the GVWR. 1250 is going to be a rough number because curb weights will vary and GVWR will vary. Max payload probably is in some places but not on the door sticker.
So you really need to know your curb weight to know how much stuff you can carry and weigh stuff as you add it. Or weigh it fully loaded and see how much under/over GVWR you are.
You could be ok for GVWR but be over on the axle ratings - probably wouldn't happen if you load correctly, but it could.
Reserve weights as mentioned don't really come into it except I need a number for the sticker. All it's telling you is a number of lbs you have left to add front/rear assuming you have 600 (or 750) lbs of passengers. Like you say maybe with a safety margin.
There might be something in the doc alwaysFlOoReD sent it's a lot of tech info very long, will take a while to sort through it.
I would assume as you said front axle rating should be the same for any '97 that has same config as mine.
To add. I looked at a bunch of '97 Ranger labels (web) and there seems basically no 2 are the same. It's important to note that the axle capacities aren't just based on the axles. 2,750 (shop manual) is the axle itself so that's a max regardless of the truck config. But if you have, say, 195/70R14 tires, the axle capacity will be less. The capacity is the -minimum- of the axle, suspension, and wheels and tires. So for instance a 195 tire has capacity 1312, times 2 is 2624, so it can't have capacity 2750. That's why in the brochure they tell you that the maximum GVWR's only apply if the tire is at least such and such.
I had 265's oem on my truck so I'd say rear axle capacity should be 2,750 (max it can ever be). I feel pretty confident about that. Front, I'm still trying to figure out. Capacity of those tires is 2469, times 2, is way over the capacity of the suspension so the limit there would be the suspension and oddly you'd think it could be found somewhere but no luck yet. Can't even find one with the same GVWR.
Its kind of like dyno charts vs seat of the pants.
My f150 supposedly tows 8400 lbs, way more than say a supercab 4x4 F150, because it is an extended cab 2wd w/ the 5.4.
It might tow that much, but not very well. I can pull it off sketchily, Joe public wouldn't stand a chance. Its mostly brakes suspension and brakes limiting it
