- Aug 19, 2001
- So. Calif (SFV)
- 2.9 V6
- Manual
- Tire Size
- 35x12.50R15
OK, so i decided to do this, but im trying to figure out how i could adjust for caster to get it closer and im terriable at reading it, so i made a picture....
Could someone tell me which it needs to be closer to. A or B?
also can some one tell me how long to cut the 2 inch pipe to make it 15 inches longer or do i need to just match it up to another radius arm and go from there? guess go from the base of the bolt and measure off there.....
Both A or B would work (Skyjacker's arms are a bit more like A than B), but like shown in BlackBII's pic, B will be far easier to implement if you're basing them off your stock arms.
For length, just measure in a straight line the length of the arm from where the axle bolts attach to the base of the stud where the front of the bushing sits. Make 'em 12" or 15" or whatever you wish longer than what the stock arm measures (12" works good if you want to keep your frame brackets separate from the trans crossmember, 15" if you'd rather incorporate the mounts into a new custom crossmember).
Eh, ive been busy, lazy, busy, and building my fab skills up by making other stuff for the truck so that this would work right. Im self taught and my access to good tools and help with any project is slim. here are a few pics.
