Exhaust leak @ cat advice
jcd302
Clarksville, MI
Where the Y pipe comes into the cat, the gasket is gone. The cat has studs that are shot. I know I am going to have to cut them, but am I going to have to drill out what is left of the studs from the cat or can they just be "popped out" like a wheel stud.
I just want to make sure I have everything before I get it torn down as we just have 1 vehicle today and I need to get the wife from work this afternoon.
Once they start leaking, they don't stop. Weld the flange together all the way around...Any exhaust shop will do the same, they won't mess with it cause it will leak again, they just weld it up, and when it comes time to replace the cat, they just cut it off and weld a new one on :icon_thumby:
SVT
OK, couldn't get the welder to ground out even after clamping right to the flange I was welding (I'll search across the shop for my face shield later).
So now it is laugh time. I mixed some JB Weld and stuffed it in the seam. Praying this works because I don't want to put more money into this truck. When I was under there I found out the rear of the frame was grafted on. Slightly peeved right now...
I had the same problem but my studs were already removed (if they were even there to begin with). I used new bolts all the way around.
My problem was a leak that I could not fix. I would try new gaskets with no luck because it turned out that the flange was warped.....
I could never get it to seal...After many attempts at sealing it, What finally held it was to use two gaskets and Ultra Copper high temp sealant.
What you do is take one of the gaskets and make a bead around the inside of one. Then sandwich it with the other gasket (make sure they face the correct way and fit inside of each other) Then use some more of the sealant out side of the gasket sandwich. THEN once it's in and installed, put some more on along the seam of the whole thing to really seal it up. It's worked great for me and it's been like this for a long time.
jb weld wont work it will get to hot and just fall off.
double or triple the gaskets and put a bead of permatex ultra copper RTV inbetween each layer and on each flange.
and yes knock the studs out and use new bolts with copper anti seize
I've never had a joint leak after using Ultra Copper on it. That's what is on mine, no gasket at all, just the RTV.
yeah that shit is the best! i use it on everything.
it even sealed up agaist the notorious ford FE passenger exhaust manifold leak
