Excess warm up time
Bronconagurski
Bronconagurski
Butte MT
2.8 V6
Total Drop
Do the right thing
Hi guys, I have to warm up my 85 broncoii for 7-10 min or it Wil l stall, buck and smoke! If I give it the 7-10 warm up it.runs great. Any ideas?
Welcome to TRS :)
Your Choke setup on the 2.8l carburetor is not working.
All gasoline engines need to run Rich with high idle and advanced spark timing when they are cold, thats what the Choke Plate does on a carbureted engine .
Before starting cold you need to press gas pedal down to the floor one time, to set the choke plate
It needs to close on cold start, which restricts air coming into engine, this causes more gasoline to be sucked out of the Jets, Rich Mix, there is also a cam on the throttle linkage that should increase idle when choke plate closes.
Welcome to TRS :)
