89 Ford RaNGER 2.9 Manual trans swapped in a reman 4.0 and used 91 ford ranger auto wire harness
Made this swap a few weeks ago. The biggest difference on electrical was the C105F (FireWall Big white connector Plug) Repinned and got everything working for the most part. Guages lights etc. Truck ran good for a week put about 200 miles on in it. Went back into plug and swapped two pins thinking I was fixing the radio memory issue. It was a black/white (12 volts) not being used from 91 harness into a slot 14 which in the 89 was a black white that I now know an to Clutch PS, ABS and Manual trans. Cranked motor over and got no start. Switched wires back. Truck fired up but all the sudden had low idle and now a check engine light on of the first time. I drove the truck around 10 minutes ran good still low idle (500rpm) but wouldn't die all gauges read good but CEL stayed on. Turned it off and went to restart, it just cranks.
I have spark, fuel, fuel, pressure, injector pulse. But truck will not restart if warm. If it sits for 15 20 minutes it will fire right up, CEL pops on in 5-10 sec and idle goes low within a minute. Truck will run until you shut it off. Once off and go for restart it will not fire just crank.
I replaced TPS, Coil pack, Swapped 3 EDIS6, New MAF, New IAC, New temp sensor, HEGO sensor. Checked all fuses and relays (Initially had HEGO fuse blown, replaced and now good)
No more fuses blowing and still same issue.
I started checking grounds to EDIS 6 plug. Black and White ground is good to power ground but the Ignition ground Orange and Red coming from computer is reading 5ish volts? Why would this be? I have read a poor or bad ground to the ECU but I am not finding anything burned.
I believe this is the problem any help on next move would be greatly appreciated.
I also checked continuity on blue wire and grey wires going from EDIS to CPS they tested good. All yellow ignition wires should be good because its firing.
