Escort's Project Family Wheeler
And it is about time you go back to Barstow.
NP208, will that work with this transmission?
Sent from my SM-N910T using Tapatalk
Yup. The np203, 205, 208 (okay all fullsize transfercases) have the same bolt pattern.
I do suggest getting one with fixes yoke outputs. Can be found on full-size f150s with extended cabs. I have one from a standard cab and is a slip yoke but seeing as you are a flex whore, you run the risk of the slip yoke coming out.
I have a friend that is selling a 82 bronco for 300 with no title. But I don't need the whole truck
I'm told (and read somewhere) that the Bronco have a different pattern than the F-150s
Waiting for the tow truck to take it to the transmission shop. I just decided to let them do it all.
This way you get a warranty as well.
Sent from my iPad avoiding something that I should be doing right now.
Exactly.
Picked up a BW4406 today.
Those are pretty big (tall) but should fit under an explorer.
I did a little research on them. It will fit the explorer better than a ranger. I also have to modify it a little or try to find a slip yoke eliminator
Oh, and it's a manual shift that came with all brackets, linkage and shifter and front shaft.
Just have to cut a hole in the floor.
Featured Ranger Based Vehicle
