- Jun 13, 2025
- Denver, CO
- State - Country
- CO - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.9L
Hey guys, hoping somebody who has worked with multiple 2.9L motors can give me some knowledge.
I've got a 2.9L with a FM146 5 Speed Mitsubishi Manual transmission, I replaced the starter last week and realized:
1) The metal plate between the transmission and motor is bent, guessing this is from me using a jack to support the trans to replace the mount. Haven't had any issues with leaking fluid from here, but I am not super knowledgeable on this scope of work.
2) There is (what I thought was) a missing bolt opposite of the starter. More specifically, the passenger side on the very bottom of the mating point. Pretty much exactly mirroring the location of the bottom starter mounting bolt.
Today I was watching another person's restoration video and they did a starter replacement, but I noticed that they also did not have a bolt where I had previously suspected one was missing. Also noticed that the metal plate between the trans/motor on theirs was also a bit chewed up.
I will provide photos if needed, but curious if anybody knows off hand if this is actually the way these came from the factory?
Also, would you say that the now malformed plate between the two is something I should be concerned about at this point.
TYIA.
TYIA.
