ecm bronco 2
ccordell
does anyone have a 90 ecm and wire harness without egr valve and knock sensor. I think Im in dire need of one.
Ug. Pull your 90 engine back out, strip it down to the long block, and swap all of your old sensors and manifolds, then put it back in.
its done gone. everything was same except it didnt have egr or knock sensor. Now I'm stuck
can I not just put a 90 ecm and harness in it and it work
Maybe....
The 90 harnesses are a bit different. You may need to swap the dash out to make it work right. Not 100% sure on that.
You think I could just add the egr and knock sensor to it.
Post your original issue down in the 2.9L Forum. There are ways to do it, yeah, but there are parts you are gonna need.
The guys who pop in there will probably know the specifics of it better than I do.
