I took the top off the carb while on level and my float was actually a little low. But I got it set right at 3/4" now. Fuel is not dripping out of the accelerator pump or the power valve that I can tell. I am attaching a couple of pictures. The one with my finger in it is pointing right to where I saw the fuel seeping. It was above the spacer on the front right corner of the carb. Because I was adjusting the float level - I did get some gas splashing out of the carb tonight so I was unable to see if it was happening tonight.
I wasn't sure which short hose to the manifold you were talking about....but the one that is beneath the carb (that I have plugged) did not have fuel in it when I pulled it off. You can see the plugged hose I am talking about in one of the pictures.
I appreciate your help - I'm trying to be descriptive as possible when explaining what is going on, but let me know if something doesn't make sense or I am not explaining it clear enough. Thanks!
