bigfattruckerll
- Nov 30, 2008
sorry it has two 15 gal tanks
That rgw Ranger Aux tank can be adapted to any Ranger, but before you even think about doing it you first need to understand several things.
An unrusted Ranger Aux tank is the closest thing to a "living fossil"
as you can get when discussing RBV parts.
Finding a useable pickup-sender unit is like finding a large sack of kugerrands
in the trunk of a rusted ford Maverick
And even if you have a good sender unit the sender won't work
with the later instrument panel guage AND the early tank unit
uses only a LOW PRESSURE pump.
It should be noted that you cannot buy either of these parts new.
Lastly not many people wand to decrease the fuel capacity of their truck.
OR use a smaller tank than will fit.
AD
I have a 1988 xlt ford ranger with a long bed and I was stoked to see it also had dual gas tanks.I didnt see any other place to post this so I'm posting it here.
In looking thru the body parts section at LMC Trucks I noticed up to 88 you can buy a bedside panel that has Dual fuel openings in it. I was very suprised by this as I have never seen a dual tank option on a Ranger, Any Ranger.
Has anybody ever seen dual tanks on a Ranger. What years were they avaible and could one be retro-fitted on a 89. Wonder were you would even find parts for that. So whats the story of dual fuel tanks on a Ranger as I would sure like to know. Thanks...
LV
ummm.... no.I have just purchased a 1988 ford ranger long bed with dual gas tanks. The owner said he’s never used the rear. To find out if it works is it safe to just throw some gas in and see if she cruises?
Heard that!!!ummm.... no.
you are asking for a breakdown, heartache and creeping underwear if you do...
how long has the PO owned the truck? if it has been more than a few months, chances are there are some nasty's that probably need to be cleaned out. best case scenario, you will clog your fuel filter, worst case, you will gum up your injectors and it will leave you stranded. clean out the tank, make sure it does not leak... there is likely a reason it has not been used... unhook the gas line from it and run the fuel out of it via its own pump and make sure it flows freely and is clean. probably would not hurt to replace the fuel line to that tank. make sure that the filler neck is good. hook it back up again, and disconnect just before the fuel filter and run some more gas out of it...if it is good hook it back up.
Hopefully it won't leak and the fuel pump is good. I don't think it is easy to get parts for the rear tank on these trucks...
AJ
I have that setup in my Truck. You need the tank , the cross member, the fuel lines, the tank selection cross over valve system and the switch in the dash. The only way I see it, is to find one in the wrecking yard and get all of those parts.I didnt see any other place to post this so I'm posting it here.
LV
A tank without gas in it rusts from the condensation in the tank. It is best to remove the tank, clean it, coat it on the inside with something, and then use it. Plan on replacing all the fuel lines and the vent tube rubber while you have it. Make sure the ground wire for the gauge is good. If you do not have a one way vent on your tank vent and go off road a lot, a one way valve from SpiderTrax would not hurt. Be careful removing the filler hose and do not try to just yank it off.I have just purchased a 1988 ford ranger long bed with dual gas tanks. The owner said he’s never used the rear. To find out if it works is it safe to just throw some gas in and see if she cruises?
