Driving question
How did you overheat the brakes? I've had heavy loads on mountainsides and just pumped them to keep it under control without heating them up
And I don't have a lot of experience with auto trans, I mean, I've had them, but probably 95%+ of the vehicles I ever had were manuals and if it was that I wouldn't have such questions because I'd know what to do just by instinct. So it's not unlikely that I ask some questions that seem obvious to others then in retrospect I usually go, of course, how could it be otherwise.
A automatic is not as good as a manual, but in certain situations you can treat it somewhat like a manual and it can be helpful. On most of my automatics, when I pull a mountain I will pull it down out of overdrive at least. The auto trans will take care of itself, but I do not like it downshifting going up the hill, then when I slow down and go around a curve, it goes back into overdrive, and then after the curve it drops out of overdrive, and it does this all the way up the mountain. I just force it to stay out of overdrive.
My understanding about brake warping is that the rotors don’t actually warp. What happens is when you get them really hot, from riding them or whatever, then you stop and hold the brakes. When you stop the brake pad material gets fucked up and gets stuck to the rotors. The only way to fix it is to turn the rotors or replace them. Hence why people think they’re warped. I think I read that in HotRod or something.
To the point about driving down a slippery hill. If it’s real slippery the tires will lock up easy when you hit the brakes and you can loose control. when in 2wd, same thing can happen in 2wd when downshifting to engine brake, back will loose traction and spin you around.
In 4wd, engine braking will slow everything down at the same time, so less likely to loose traction all at once.
Downshifting during a skid can keep it straight during a 2wd slide, on snow or ice also, actually just letting off the gas will straighten it up
I could answer 75% of James' questions by taking him for a ride in a good offroad park. Wouldn't have to say a word except "keep your body parts INSIDE the truck at all times and stop screaming".
@James Morse ,
A productive practice is to scout out the trail on a dirt bike 1st, then when in the truck... REMEMBER that it, isn't a DIRT BIKE!!
Here's the thing at idle on the level, in D you're going what, 8-10mph? Something anyway. So if you're not going at least that, you won't get engine braking from the trans. Unless I'm missing something here.
So in conclusion i may of been talking out my ass but 8-10 seems fast lol
Since we're talking out our ass here...
If you're going that slow without touching the brakes, are you generating enough heat in the brakes to worry about it?
Depends how long youre dragging them at a low speed
Pad material can etch into the rotor during storage if exposed to moisture, excess heat warps rotors.
As a Lathe man at a brake shop for almost 3 years, I can say this is wrong. I have turned rotors by the truck load. They DO get warped. I've seen them where they wouldn't even sit flat on the concrete floor. It's not the hat that warps, it's the actual disc.
That isn't a muddy road. This is.
Nice! You don't even need to steer there :D
