im gettin ready to put the new rear end in the truck and after that ill be dropping the 302 and aod in. its a nine inch with 3.73s. will i be able to use my original driveshaft?
Sorry to say but probably not. Once everything is in, pull out the tape measure. To modify yours isn't that expensive.
about how much do you think that could cost
If you are worring about the driveshaft cost, don't even think of a v8 conversion because it is very expensive or at least mine has been..Mike
Count on modifing the rear connection and most likely the length. There are about ten different rear yoke versions for the nine inch. Might run $50-100 to have the length corrected and then balanced.
Dave
i just payed 120 to have a new yoke welded on the front of my 2-piece unit. and have it shortened.
the it was another 80 to have it spin balanced.
but new york prices are always more expensive
