1BadRS
I'm in the process of converting to the duraspark and I'm getting hung up on getting this distributor in.
My issue is with the new o ring not letting the distributor fully seat on the block. It gets hung up right as it gets to the o ring and even with some pressure it won't slide fully in. When I remove the o ring I can get the distributor to fully seat no problem.
Can I slide the o ring up on the shaft past the groove so it would basically sandwich between the block and distributor to prevent oil leaks? If not what do you suggest?
Thanks
Thanks
