disciplerocks's Ford Focus "build" thread
Good enough to move around.
There's still bugs to work out.
I hear that. The 4.0 runs, it drives, it feels great, but it has this awful tick that I just can't figure out, and being as crazy as I am I can't get the stupid thing out of 3rd gear with this noise because I think some part of the rotating assembly will make a dramatic exit from the block.
As good as the 4.0 is, its still a bored 2.9
Yeah, but it the same torque curve as the 5.0 and fits better. Plus, no TFI, no distributor.
Plus, it's not a 2.9. I like the cologne engines, I really like this thing in my Ranger, for all that I have driven it, but I just wish it wasn't making this noise.
I like mine in the B2. I don't ever see a need to upgrade further.
So far I am not seeing it either. When I put the HIPO in the truck that was like a kick in the pants vs the 200,000 mile dead horse it replaced.
I haven't even driven the truck 2 miles since the swap, but I can already feel the difference. It just seems so much smoother than the 2.9.
There's nothing that compares to the feel, sound, smell, etc.. of a 5.0.
Plus you get the option of having it carbed or FI. And you can open up just about any parts magazine and get anything you want for one too.
Sent from my rooted SPH-D710 using Tapatalk 2
I will agree that the 4.0 can never meet the sound of a small block. I am however a tad bit confused on your second point. Since when was carb ever an option?
Go EFI or go home.
It was an option till 86 lol.
I like a carbed 5.0. Has a nice slight off balance shake when idling plus the sound of the noise coming through the carb.
Only time you get that in a FI is when one of your injectors goes out on you.
Takes a real person to want to fine tune and make a carbed engine run just right, but only takes an idiot at AutoZone to plug in a scanner to an FI too tell you that you need to buy an over priced plastic part to get it to run right again.
ut oh, here we go......
Robert
sent with a fusion reactor and lighting rods.
Naww, everybody has their preferences and I understand. My decisionon was based on what I could afford to do but also I wanted to learn how things were done back in the days before everything was controlled by electronics.
Would I like to go FI in my truck, you bet but only if a carb setup gives me to much trouble on the trials, offroading, etc... and if I can get the money. But that's when I can afford to build a 302 from scratch, aiming for 300-325hp n/a.
Sorry for the thread jack, back to the 5.0 focus.
buddy of mine had abeast of a 289 Hi-Po out of an old Mustang in his Jeep...carb would let him down on the trail...he tried Holley's, Quadra-Jets, and even a "Truck Avenger" with no luck....
he rocks a FI 5.0 in it now with no issues on the trail...
FI is only way on trails, rocks, hills, etc...anything that deviates from level much...
and I agree, the 4.0 is more than enough for me on the trails...
l8r, John
If I could find out if the efi set-up off a non HO crown vic would work on my HO 5.0 (with the help off larger injectors and larger TB) then I would do that, trying to go cheap and simple on that.
Or if I could get my hands on a 4 barrel TBI setup for cheap or integrate one into my engine that came on another vehicle type from the factory then I would try that.
I think I should just wait till I can afford to build a 5.0.
The efi setup will work, its the wiring harness and ECU that won't. You can get a 95 f series harness and ECU (which is HO) and run that, or a mustang harness/ECU, or ex 5.0 with a couple more parts...
SVT
That sounds like the winning setup. But I do want the correct type of intake setup and my pick a part usually has 5.0 explorers in it. I just don't want to mess with the explorer wiring, ecu, etc...
So 95 is the only year f150 that will have the wiring harness and ecu?
