did you take the first one apart and see if it was broke??? if it is, take the second one apart, and if it isn't broke, put those two gears in the first one and see of that works, just make sure they are the same size and all.
the newer bell housing might have different ports or something.
Yeah the pump, and fluid pathways are different between the 2. Taking off a pump and inspecting is my next step, but i am also fighting the motor in the Focus. Having 2 things that need my attention sucks. And that doesn't include the fiance!
Third time's the charm. Got out of work early today and felt a little energetic so I pulled a tranny from the u-pull and got the pump and TC from it. Then installed them on the B2, fired it up, and she started spitting fluid. Now I can finally get this thing running.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
