93shortbox
- May 3, 2010
I just bought this truck its a 93 4 cylinder, 5 speed the truck runs great for 30 minutes or so. Then it just stops running without any sign like it was turned off. If I wait a couple minutes it will fire right up like normal. I really need to fix this asap because this will be my new DD. The truck has new fuel filter, both coil packs, plugs, wires, and crank sensor. The truck was lightly hit in the bed underneath the gas door I thought because of the accident it might have messed up the fuel pump but its running at a constant 32psi at idle and at about 3k it drops to about 29psi. I was told that is normal. Could someone please point me in the right direction I need to get this thing running right so I can tag it.
