Joel orozco
I need help with my 86 ford ranger 2.9 it stalls for a while then after it starts it wont last no more then a second running after it dies any help on what could be wrong?
I will try that tomorrow and i will update you thank you so much!!Welcome to TRS
Could be a few things
1986 2.9l uses a TFI module for spark, these were a known issue
If the engine starts and runs OK while its still cold and only has re-start issue after its warmed up then I would replace the TFI module on distributor
This can also be a Coil Issue, no start when warm, but less likely than the TFI module
If the no start can happen cold or warm then probably a fuel issue
1986 has 2 electric fuel pumps, one inside the gas tank and one on the drivers side frame rail
If either fails you will get what you describe, starts but dies quickly
(Clogged fuel filter will cause that as well)
You can do the 50/50 test, been around for 100+ years
On your 2.9l pull off the big air tube that runs from air cleaner box to the upper intake, pull it off of the intake, make sure fan can't hit it
Get some gasoline in a spray bottle or Quick Start(ether)
Have some one crank the engine while you spray fuel into the intake
If engine starts and stays running while you spray in fuel, but dies when you stop adding fuel, then spark is OK, but no fuel delivery
If engine doesn't start or fire then No Spark
50/50 instant results
No it still diesWill it stay running with your foot on the throttle?
If so you need an IAC
Yeah on the throttle body my bad???
2.9l was fuel injected, no "carb"
